Ir para o conteúdo principal
Xbox One Kinect LED Sensor Replacement
O que você precisa
  1. Xbox One Kinect LED Sensor Replacement, Outer Shell: passo 1, imagem 1 %32
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    Pergunte ao FixBot
    Comentar
  2. Xbox One Kinect LED Sensor Replacement: passo 2, imagem 1 %32 Xbox One Kinect LED Sensor Replacement: passo 2, imagem 2 %32 Xbox One Kinect LED Sensor Replacement: passo 2, imagem 3 %32
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    Pergunte ao FixBot
    Comentar
  3. Xbox One Kinect LED Sensor Replacement: passo 3, imagem 1 %32 Xbox One Kinect LED Sensor Replacement: passo 3, imagem 2 %32 Xbox One Kinect LED Sensor Replacement: passo 3, imagem 3 %32
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    Pergunte ao FixBot
    Comentar
  4. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: passo 4, imagem 1 %32 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: passo 4, imagem 2 %32 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: passo 4, imagem 3 %32
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    Pergunte ao FixBot
    Comentar
Conclusão
Malak Anshassi
Membro desde: 09/22/14
356 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-3, Hickman Fall 2014 Membro de USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 34
Ao todo: 1,533
