Ir para o conteúdo principal
Xbox 360 E Button Board Replacement
O que você precisa
  1. Xbox 360 E Button Board Replacement, Top Panel: passo 1, imagem 1 %32
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    Pergunte ao FixBot
    Comentar
  2. Xbox 360 E Button Board Replacement: passo 2, imagem 1 %32
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    Pergunte ao FixBot
    Comentar
  3. Xbox 360 E Button Board Replacement: passo 3, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 3, imagem 2 %32 Xbox 360 E Button Board Replacement: passo 3, imagem 3 %32
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
    Pergunte ao FixBot
    Comentar
  4. Xbox 360 E Button Board Replacement, Bottom Panel: passo 4, imagem 1 %32
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
    Pergunte ao FixBot
    Comentar
  5. Xbox 360 E Button Board Replacement: passo 5, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 5, imagem 2 %32
    • Slide the spudger along the crevice to separate the grated face and the top body.
    Pergunte ao FixBot
    Comentar
  6. Xbox 360 E Button Board Replacement: passo 6, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 6, imagem 2 %32 Xbox 360 E Button Board Replacement: passo 6, imagem 3 %32
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
    Pergunte ao FixBot
    Comentar
  7. Xbox 360 E Button Board Replacement, Front Panel: passo 7, imagem 1 %32 Xbox 360 E Button Board Replacement, Front Panel: passo 7, imagem 2 %32 Xbox 360 E Button Board Replacement, Front Panel: passo 7, imagem 3 %32
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    Pergunte ao FixBot
    Comentar
  8. Xbox 360 E Button Board Replacement: passo 8, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 8, imagem 2 %32 Xbox 360 E Button Board Replacement: passo 8, imagem 3 %32
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
    Pergunte ao FixBot
    Comentar
  9. Xbox 360 E Button Board Replacement: passo 9, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 9, imagem 2 %32 Xbox 360 E Button Board Replacement: passo 9, imagem 3 %32
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    Pergunte ao FixBot
    Comentar
  10. Xbox 360 E Button Board Replacement: passo 10, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 10, imagem 2 %32 Xbox 360 E Button Board Replacement: passo 10, imagem 3 %32
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
    Pergunte ao FixBot
    Comentar
  11. Xbox 360 E Button Board Replacement: passo 11, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 11, imagem 2 %32
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
    Pergunte ao FixBot
    Comentar
  12. Xbox 360 E Button Board Replacement: passo 12, imagem 1 %32 Xbox 360 E Button Board Replacement: passo 12, imagem 2 %32 Xbox 360 E Button Board Replacement: passo 12, imagem 3 %32
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
    Pergunte ao FixBot
    Comentar
  13. Xbox 360 E Button Board Replacement, Button Board: passo 13, imagem 1 %32 Xbox 360 E Button Board Replacement, Button Board: passo 13, imagem 2 %32 Xbox 360 E Button Board Replacement, Button Board: passo 13, imagem 3 %32
    • Rotate the front panel so you are looking at the inside of the piece.
    • Unscrew the six 6 mm screws with the T6 Torx screwdriver.
    • Carefully pull the green plate up and off to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
Jennifer
Membro desde: 02/02/14
2.194 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-11, Amido Winter 2014 Membro de Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Membros
Autoria de 44 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 39
Últimos 30 dias: 210
Ao todo: 15,118
