Ir para o conteúdo principal
X-Treme Tablet Generation 2 Battery Replacement
O que você precisa
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: passo 2, imagem 1 %32 X-Treme Tablet Generation 2 Battery Replacement: passo 2, imagem 2 %32 X-Treme Tablet Generation 2 Battery Replacement: passo 2, imagem 3 %32
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: passo 3, imagem 1 %32 X-Treme Tablet Generation 2 Battery Replacement: passo 3, imagem 2 %32
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
Conclusão
Mike Longshore
Membro desde: 01/28/15
125 Reputação
Autoria de 1 guia
Equipe
Pasco Hernando, Team 5-4, Prince Winter 2015 Membro de Pasco Hernando, Team 5-4, Prince Winter 2015
PHSC-PRINCE-W15S5G4
Membros da 6
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,096
