Ir para o conteúdo principal
WowWee MiP Robot Battery Replacement
O que você precisa
    1. WowWee MiP Robot Battery Replacement, Battery: passo 1, imagem 1 %32 WowWee MiP Robot Battery Replacement, Battery: passo 1, imagem 2 %32
      • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
      Pergunte ao FixBot
      Comentar
    2. WowWee MiP Robot Battery Replacement: passo 2, imagem 1 %32 WowWee MiP Robot Battery Replacement: passo 2, imagem 2 %32
      • Carefully pull the battery pack from the robot.
      • Remove the batteries from the battery pack.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Moira Keahon
Membro desde: 09/24/14
257 Reputação
Autoria de 3 guias
Equipe
14Comentários do guia
Its a programmer MIP not this kind.
Azariah Trumble - Responder Compartilhar
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
Gil Acosta - Responder Compartilhar
does spare battery adapter vailable(not reachargeable)
coolboyz' channel - Responder Compartilhar
Coder Mip Battery says fully charged - but Coder Mip doesnt turn on?
Sadie - Responder Compartilhar
Coder MiP one day old - was working - battery says fully charged - but Coder MiP doesn’t turn on? Any suggestions?
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 58
Ao todo: 13,969
