Ir para o conteúdo principal
Wooting 60HE Keycap Replacement
O que você precisa
    1. Wooting 60HE Keycap Replacement, Keycap: passo 1, imagem 1 %32
      • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
      • For this replacement, we will be replacing the "A" keycap.
      Pergunte ao FixBot
      Comentar
    2. Wooting 60HE Keycap Replacement: passo 2, imagem 1 %32 Wooting 60HE Keycap Replacement: passo 2, imagem 2 %32
      • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
      • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
      • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
      Pergunte ao FixBot
      Comentar
    3. Wooting 60HE Keycap Replacement: passo 3, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
      • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
      Pergunte ao FixBot
      Comentar
    4. Wooting 60HE Keycap Replacement: passo 4, imagem 1 %32
      • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
      • Press the trigger in short bursts.
      • This will help get rid of any debris that you could not get from using your tweezers.
      Pergunte ao FixBot
      Comentar
    5. Wooting 60HE Keycap Replacement: passo 5, imagem 1 %32 Wooting 60HE Keycap Replacement: passo 5, imagem 2 %32
      • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
      Pergunte ao FixBot
      Comentar
    6. Wooting 60HE Keycap Replacement: passo 6, imagem 1 %32
      • Gently pat around the white backboard of the keyboard with the cotton swab.
      • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
      • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
      Pergunte ao FixBot
      Comentar
    7. Wooting 60HE Keycap Replacement: passo 7, imagem 1 %32 Wooting 60HE Keycap Replacement: passo 7, imagem 2 %32 Wooting 60HE Keycap Replacement: passo 7, imagem 3 %32
      • Line the keycap in the upright position above the nub and press down lightly.
      • The key should slide back in place.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Aryav Balia
Membro desde: 10/25/23
157 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membro de CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 58
Ao todo: 1,633
