Introdução
If no electricity flows through the toaster when plugged in, try replacing the electrical connection with this guide.
O que você precisa
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
Uma outra pessoa concluiu este guia.
1Comentário do guia
Thank you for you work on this toaster. My customer is happy.
