Ir para o conteúdo principal
Whirlpool WED5100VQ1 Dryer Door Switch Replacement
O que você precisa
  1. Whirlpool WED5100VQ1 Dryer Door Switch Replacement, Door Switch: passo 1, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement, Door Switch: passo 1, imagem 2 %32
    • Unplug the dryer's power cord.
  2. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 2, imagem 1 %32
    • Open and remove the lint screen.
  3. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 3, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 3, imagem 2 %32
    • Remove the screws next to the lint screen opening.
  4. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 4, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 4, imagem 2 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 4, imagem 3 %32
    • From the front of the dryer, insert a prying tool in the seam where the locking tabs are located (about 2 inches away from a corner).
    • Be sure the prying tool sits above the two legs of the locking tab.
    • Press the tool to release the locking tab.
    • Lift the top of the dryer.
    • Caution: Forcing the top of the dryer to lift without fully releasing the locking tab could result in pinching, crushing, or shearing of your fingers and hands.
    • Repeat the step on the opposite corner to fully release the top of the dryer.
  5. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 5, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 5, imagem 2 %32
    • Lift the top of the dryer 90 degrees to lock it in place.
    • If necessary, pull out the dryer until there's enough space for the top of the dryer to open 90 degrees.
  6. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 6, imagem 1 %32
    • Open the dryer door.
  7. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 7, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 7, imagem 2 %32
    • Remove the screws next to the door switch.
    • The drier door switch should be located at the upper right corner of the door frame.
  8. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 8, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 8, imagem 2 %32
    • From the top of the dryer, pinch and push down on the mounting tabs holding the dryer door switch to unplug them.
  9. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 9, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 9, imagem 2 %32
    • Pull out and disconnect the door switch.
    • If necessary, insert a prying tool into the door switch’s push-in connector to disconnect.
  10. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 10, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 10, imagem 2 %32
    • Grab and align the new door switch’s connector with the wire harness.
    • Insert the new door switch's connector into the wire harness until snug.
  11. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 11, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 11, imagem 2 %32
    • Place the door switch to its original location.
    • Ensure the door switch’s screw sockets align with the dryer's screw holes.
  12. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 12, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 12, imagem 2 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 12, imagem 3 %32
    • From the front, hold the door switch in place
    • Continue to hold the door switch in place until the screws are in place and fully tightened.
    • Hand-tighten the screws to secure the door switch.
    • Finish tightening the screws using a screwdriver.
  13. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 13, imagem 1 %32
    • On the top side of the dryer, plug the switch’s mounting tab back in place.
  14. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 14, imagem 1 %32
    • Close the dryer door.
  15. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 15, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 15, imagem 2 %32
    • Close the top of the dryer.
    • Press down the top of the dryer to lock it in place.
  16. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 16, imagem 1 %32
    • On the lint screen opening, put the two screws back in place.
  17. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 17, imagem 1 %32
    • Close and/or return the lint screen.
  18. Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 18, imagem 1 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 18, imagem 2 %32 Whirlpool WED5100VQ1 Dryer Door Switch Replacement: passo 18, imagem 3 %32
    • Plug the dryer's power cord back in.
    • If you pulled the dryer out earlier, push it back to the original location first.
    • Adjust the dryer vent as needed to avoid crushing it while pushing back the dryer to its original location.
Linha de Chegada
David
Membro desde: 09/20/24
277 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Ao todo: 37
