Introdução
Over time, a refrigerator’s water filter becomes old and needs a replacement to keep your water clean and healthy. If your water filter replacement light is blinking. Luckily, replacing the water filter in a Whirlpool Side By Side Refrigerator is not difficult at all!
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS325FDAM04 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
O que você precisa
Flush the water system by holding the water dispenser for 5 seconds and releasing for 5 seconds repeating this step until water begins to flow.
After water flowing, get at least a total of 3 gallons dispensed in order to see full flushed water results.
After flushing the water system completely, get ready to have some refreshing water with a cup of ice freshly made with the new installed water filter.
8Comentários do guia
Changed filter but now water is not coming out of the dispenser. Installed filter correctly per pictures. What could be the problem?
You will have air in the system after changing the filter. Make sure you did turn the water on. Run the water dispenser until water pushes the air out. Run the water until it clears.
Opened the filter door but the filter did not eject. Any troubleshooting advice on how to remove the filter?
You'll want to rotate the filter counterclockwise until it pops out.
Filter door will not open all the way.
