Ir para o conteúdo principal
Whirlpool Refrigerator Start Relay Assembly Replacement
O que você precisa
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    Pergunte ao FixBot
    Comentar
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: passo 2, imagem 1 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: passo 2, imagem 2 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
    Pergunte ao FixBot
    Comentar
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: passo 3, imagem 1 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: passo 3, imagem 2 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: passo 3, imagem 3 %32
    • Pull the rear panel off the chassis to remove it.
    Pergunte ao FixBot
    Comentar
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: passo 4, imagem 1 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: passo 4, imagem 2 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: passo 4, imagem 3 %32
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
    Pergunte ao FixBot
    Comentar
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: passo 5, imagem 1 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: passo 5, imagem 2 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: passo 5, imagem 3 %32
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
    Pergunte ao FixBot
    Comentar
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: passo 6, imagem 1 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: passo 6, imagem 2 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: passo 6, imagem 3 %32
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the run capacitor, start relay, and overload relay.
    Pergunte ao FixBot
    Comentar
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: passo 7, imagem 1 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: passo 7, imagem 2 %32 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: passo 7, imagem 3 %32
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
5 outras pessoas executaram este guia.
nicO
Membro desde: 04/14/15
15.990 Reputação
Autoria de 89 guias
3Comentários do guia
Is it universal part
dyannatorres@yahoo.com - Responder Compartilhar
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO - Responder Compartilhar
Last part is not clear about where to put multimeter probes for testing each component. It makes the whole exercise useless.
Shafeeq Qaiser - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 101
Últimos 30 dias: 486
Ao todo: 16,746
