Ir para o conteúdo principal
Whirlpool Refrigerator Icemaker Assembly Replacement
O que você precisa
  1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    Pergunte ao FixBot
    Comentar
  2. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: passo 2, imagem 1 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: passo 2, imagem 2 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
    Pergunte ao FixBot
    Comentar
  3. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: passo 3, imagem 1 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: passo 3, imagem 2 %32
    • Pull the icemaker tray completely out of its slot in the chassis.
    Pergunte ao FixBot
    Comentar
  4. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: passo 4, imagem 1 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: passo 4, imagem 2 %32
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
    Pergunte ao FixBot
    Comentar
  5. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, imagem 1 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, imagem 2 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, imagem 3 %32
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
    Pergunte ao FixBot
    Comentar
  6. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, imagem 1 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, imagem 2 %32 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, imagem 3 %32
    • Disconnect any connectors attached to the icemaker assembly.
    Pergunte ao FixBot
    Comentar
  7. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: passo 7, imagem 1 %32
    • Remove the icemaker assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.990 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 76
Últimos 30 dias: 441
Ao todo: 9,763
