Ir para o conteúdo principal
Whirlpool Refrigerator Condenser Fan Replacement
O que você precisa
    1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: passo 1, imagem 1 %32
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Pergunte ao FixBot
      Comentar
    1. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 3 %32
      • Remove the screw(s) securing the rear panel.
      • Loosen the screw securing the water hose enough for the rear panel to freely move.
      Pergunte ao FixBot
      Comentar
    2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 3 %32
      • Pull the rear panel off the chassis to remove it.
      Pergunte ao FixBot
      Comentar
    1. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: passo 4, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: passo 4, imagem 2 %32
      • Disconnect the connector attached to the condenser fan.
      Pergunte ao FixBot
      Comentar
    2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 3 %32
      • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
      • Pull the condenser fan straight off its peg to remove it.
      Pergunte ao FixBot
      Comentar
    3. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: passo 6, imagem 1 %32
      • Remove the screw(s) securing the condenser fan motor to the chassis.
      Pergunte ao FixBot
      Comentar
    4. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, imagem 3 %32
      • Rotate the motor housing through its slot in the chassis.
      • Remove the motor.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
5 outras pessoas executaram este guia.
nicO
Membro desde: 04/14/15
15.990 Reputação
Autoria de 89 guias
1Comentário do guia
Saludos una consulta el giro del motor es antihorario???
Edward Vasquez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 39
Últimos 30 dias: 161
Ao todo: 5,508
