Ir para o conteúdo principal
Wen 2307 Speed Adjustment Assembly Replacement
O que você precisa
    1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: passo 1, imagem 1 %32
      • Unscrew the locking sleeve.
      Pergunte ao FixBot
      Comentar
    2. Wen 2307 Speed Adjustment Assembly Replacement: passo 2, imagem 1 %32
      • Remove the hanging clip.
      Pergunte ao FixBot
      Comentar
    3. Wen 2307 Speed Adjustment Assembly Replacement: passo 3, imagem 1 %32 Wen 2307 Speed Adjustment Assembly Replacement: passo 3, imagem 2 %32
      • Unscrew the six 8mm PH2 screws.
      Pergunte ao FixBot
      Comentar
    4. Wen 2307 Speed Adjustment Assembly Replacement: passo 4, imagem 1 %32
      • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
      Pergunte ao FixBot
      Comentar
    5. Wen 2307 Speed Adjustment Assembly Replacement: passo 5, imagem 1 %32
      • To remove the front panel, pry the device apart while holding the device with the other hand.
      • The front panel should come out easily.
      Pergunte ao FixBot
      Comentar
    1. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: passo 6, imagem 1 %32 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: passo 6, imagem 2 %32
      • Identify the screws.
      • Unscrew the two 3mm phillips PH2.
      • Don't forget to put them appart from the ones unscrewed before.
      • Phillips PH2
      • Flathead 2.5mm
      Pergunte ao FixBot
      Comentar
    2. Wen 2307 Speed Adjustment Assembly Replacement: passo 7, imagem 1 %32
      • Remove the place boar carefully.
      Pergunte ao FixBot
      Comentar
    3. Wen 2307 Speed Adjustment Assembly Replacement: passo 8, imagem 1 %32
      • Pull out the power cable connectors.
      Pergunte ao FixBot
      Comentar
    4. Wen 2307 Speed Adjustment Assembly Replacement: passo 9, imagem 1 %32
      • Pull out the cord sleve for the new cable replacement.
      Pergunte ao FixBot
      Comentar
    1. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: passo 10, imagem 1 %32
      • Remove the connected wiring from the circuit board.
      Pergunte ao FixBot
      Comentar
    2. Wen 2307 Speed Adjustment Assembly Replacement: passo 11, imagem 1 %32
      • Remove the single 4mm screw retaining the circuit board.
      Pergunte ao FixBot
      Comentar
    3. Wen 2307 Speed Adjustment Assembly Replacement: passo 12, imagem 1 %32
      • Gently pry the circuit board from the back piece.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 12-1, Eyestone Spring 2016 Membro de USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 28
Ao todo: 1,188
