Ir para o conteúdo principal
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
O que você precisa
  1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: passo 1, imagem 1 %32
    • Remove the knob from the adjustment dial.
  2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 2, imagem 1 %32
    • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
  3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 3, imagem 1 %32
    • Remove the rubber feet to access the remaining screws.
  4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 4, imagem 1 %32
    • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
  5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 5, imagem 1 %32
    • Separate the bottom and top half of the soldering station.
  6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 6, imagem 1 %32
    • Remove the adjustable heat dial board.
  7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 7, imagem 1 %32 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 7, imagem 2 %32
    • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
  8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 8, imagem 1 %32 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 8, imagem 2 %32
  9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 9, imagem 1 %32
    • Remove the TRIAC switch when all the solder is removed from the pins.
  10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 10, imagem 1 %32
    • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
  11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 11, imagem 1 %32
    • Solder the new TRIAC switch onto board.
  12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 12, imagem 1 %32
    • Verify all three pins are soldered in and the solder is not touching the other pins.
  13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 13, imagem 1 %32
    • Re-install the board into the soldering station.
  14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 14, imagem 1 %32
    • Push the knob into the hole so that is it protruding out of the other side.
  15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 15, imagem 1 %32
    • Verify the knob is sticking out of the other side of soldering station.
  16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 16, imagem 1 %32
    • Replace the dial onto the knob.
  17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: passo 17, imagem 1 %32
    • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 1,324
