Ir para o conteúdo principal
Waring Pro SB30 Plastic Sides Replacement
O que você precisa
    1. Waring Pro SB30 Plastic Sides Replacement, Back Panel: passo 1, imagem 1 %32
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      Pergunte ao FixBot
      Comentar
    2. Waring Pro SB30 Plastic Sides Replacement: passo 2, imagem 1 %32 Waring Pro SB30 Plastic Sides Replacement: passo 2, imagem 2 %32
      • Using a wrench, remove the bolt from the center of the back panel.
      Pergunte ao FixBot
      Comentar
    3. Waring Pro SB30 Plastic Sides Replacement: passo 3, imagem 1 %32
      • The back panel can now be easily lifted off.
      Pergunte ao FixBot
      Comentar
    1. Waring Pro SB30 Plastic Sides Replacement, Plastic Sides: passo 4, imagem 1 %32 Waring Pro SB30 Plastic Sides Replacement, Plastic Sides: passo 4, imagem 2 %32
      • Using a #1 Phillips screwdriver bit or a ratchet wrench with a Phillips screwdriver bit to remove screws located on the interior frame.
      • The interior edges of the metal frame are sharp and can cause minor cuts.
      Pergunte ao FixBot
      Comentar
    2. Waring Pro SB30 Plastic Sides Replacement: passo 5, imagem 1 %32
      • Plastic sides should be easily removed after all screws are taken out.
      Pergunte ao FixBot
      Comentar
Conclusão
Sun Fai Lau
Membro desde: 09/22/14
588 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 10-7, Brown Fall 2014 Membro de USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 489
