Ir para o conteúdo principal
Waring Pro SB30 Indicator Lights Replacement
O que você precisa
    1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: passo 1, imagem 1 %32
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      Pergunte ao FixBot
      Comentar
    2. Waring Pro SB30 Indicator Lights Replacement: passo 2, imagem 1 %32 Waring Pro SB30 Indicator Lights Replacement: passo 2, imagem 2 %32
      • Using a wrench, remove the bolt from the center of the back panel.
      Pergunte ao FixBot
      Comentar
    3. Waring Pro SB30 Indicator Lights Replacement: passo 3, imagem 1 %32
      • The back panel can now be easily lifted off.
      Pergunte ao FixBot
      Comentar
    1. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: passo 4, imagem 1 %32
      • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
      Pergunte ao FixBot
      Comentar
    2. Waring Pro SB30 Indicator Lights Replacement: passo 5, imagem 1 %32 Waring Pro SB30 Indicator Lights Replacement: passo 5, imagem 2 %32
      • Push the screwdrivers inward and guide the bulb outwards.
      • Gently grab by the wires and remove bulb from plastic shell.
      Pergunte ao FixBot
      Comentar
Conclusão
Sun Fai Lau
Membro desde: 09/22/14
588 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 10-7, Brown Fall 2014 Membro de USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 623
