Introdução
The hot plate is held in place by multiple screws along the burner ring and electrical wires. When free from the frame, take care when removing the iron plate itself as it is fairly dense.
O que você precisa
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
Remove screws #1 Phillips screwdriver bit.
3 screws on the perimeter of the circle
1 screw in the circle
2 screws on the eletrical stands with wires
