Ir para o conteúdo principal
Wacom Intuos4 Motherboard Replacement
O que você precisa
  1. Wacom Intuos4 Motherboard Replacement, Casing: passo 1, imagem 1 %32 Wacom Intuos4 Motherboard Replacement, Casing: passo 1, imagem 2 %32 Wacom Intuos4 Motherboard Replacement, Casing: passo 1, imagem 3 %32
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Motherboard Replacement: passo 2, imagem 1 %32 Wacom Intuos4 Motherboard Replacement: passo 2, imagem 2 %32
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Wacom Intuos4 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Motherboard Replacement: passo 4, imagem 1 %32 Wacom Intuos4 Motherboard Replacement: passo 4, imagem 2 %32
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Motherboard Replacement: passo 5, imagem 1 %32 Wacom Intuos4 Motherboard Replacement: passo 5, imagem 2 %32
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
Conclusão
Jack Palmgren
Membro desde: 10/26/22
234 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 279
