Introdução
Use this guide to replace the motherboard in a Wacom Intuos4.
The motherboard is behind the functionality of your device's touchscreen and USB port. A broken motherboard could result in issues with either your touchscreen or USB port. Since the USB port is connected to the motherboard, you may have to review the iFixIt Soldering guide (Como soldar e dessoldar contatos).
This guide was created with a model PTK-640 Wacom Intuos4. Different models may vary in design.
O que você precisa
Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
Using tweezers, remove the yellow tape covering the three cable connectors.
