Ir para o conteúdo principal
Wacom Intuos Pro Touch Pad Replacement
O que você precisa
  1. Wacom Intuos Pro Touch Pad Replacement, Battery: passo 1, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement, Battery: passo 1, imagem 2 %32 Wacom Intuos Pro Touch Pad Replacement, Battery: passo 1, imagem 3 %32
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Touch Pad Replacement: passo 2, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 2, imagem 2 %32 Wacom Intuos Pro Touch Pad Replacement: passo 2, imagem 3 %32
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Touch Pad Replacement: passo 3, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 3, imagem 2 %32
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Touch Pad Replacement: passo 4, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 4, imagem 2 %32
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Touch Pad Replacement: passo 5, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 5, imagem 2 %32
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
  6. Wacom Intuos Pro Touch Pad Replacement, Touch Pad: passo 6, imagem 1 %32
    • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
  7. Wacom Intuos Pro Touch Pad Replacement: passo 7, imagem 1 %32
    • Remove the five 4.5mm screws using a Phillips #00 screwdriver.
  8. Wacom Intuos Pro Touch Pad Replacement: passo 8, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 8, imagem 2 %32
    • Gently wedge the Jimmy under the black backing of the blue touchpad.
    • Gently pry up the touchpad and remove it from the case.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 48
Ao todo: 1,642
