Ir para o conteúdo principal
Wacom Intuos Pro Battery Replacement
O que você precisa
  1. Wacom Intuos Pro Battery Replacement, Battery: passo 1, imagem 1 %32 Wacom Intuos Pro Battery Replacement, Battery: passo 1, imagem 2 %32 Wacom Intuos Pro Battery Replacement, Battery: passo 1, imagem 3 %32
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Battery Replacement: passo 2, imagem 1 %32 Wacom Intuos Pro Battery Replacement: passo 2, imagem 2 %32 Wacom Intuos Pro Battery Replacement: passo 2, imagem 3 %32
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Battery Replacement: passo 3, imagem 1 %32 Wacom Intuos Pro Battery Replacement: passo 3, imagem 2 %32
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Battery Replacement: passo 4, imagem 1 %32 Wacom Intuos Pro Battery Replacement: passo 4, imagem 2 %32
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Battery Replacement: passo 5, imagem 1 %32 Wacom Intuos Pro Battery Replacement: passo 5, imagem 2 %32
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
Conclusão
5 comentários
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - Responder
Do you know where can I find the battery replacement?
Valerio _ - Responder
Has anyone got a lint to the replacement battery?
Luca Di Meo - Responder
PTH-660 works fine without the battery, just remove it and use it with USB cable
Where can I find a replacement battery for this model?
Denise Hanly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 117
Duração total: 7,732
