Ir para o conteúdo principal
Wacom Cintiq 24HD Power Port Replacement
O que você precisa
  1. Wacom Cintiq 24HD Power Port Replacement, Stand: passo 1, imagem 1 %32
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Power Port Replacement: passo 2, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 2, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement: passo 2, imagem 3 %32
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Power Port Replacement: passo 3, imagem 1 %32
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD Power Port Replacement, Back Panel: passo 4, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement, Back Panel: passo 4, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement, Back Panel: passo 4, imagem 3 %32
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD Power Port Replacement: passo 5, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 5, imagem 2 %32
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD Power Port Replacement, Interior Metal Plate: passo 6, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement, Interior Metal Plate: passo 6, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement, Interior Metal Plate: passo 6, imagem 3 %32
    • Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
  7. Wacom Cintiq 24HD Power Port Replacement: passo 7, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 7, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement: passo 7, imagem 3 %32
    • Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise.
    • Remove the metal button plate from the back metal plate.
  8. Wacom Cintiq 24HD Power Port Replacement: passo 8, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 8, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement: passo 8, imagem 3 %32
    • Remove the button wires from the support clip by pushing down on the clip.
    • Detach the button wires from the button board by pulling the button wires away from the board.
    • Place the button board back in to the device.
  9. Wacom Cintiq 24HD Power Port Replacement: passo 9, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 9, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement: passo 9, imagem 3 %32
    • Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise.
    • Remove the two metal mounting plates.
  10. Wacom Cintiq 24HD Power Port Replacement: passo 10, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 10, imagem 2 %32 Wacom Cintiq 24HD Power Port Replacement: passo 10, imagem 3 %32
    • Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
    • Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
  11. Wacom Cintiq 24HD Power Port Replacement: passo 11, imagem 1 %32
    • Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
  12. Wacom Cintiq 24HD Power Port Replacement, Power Port: passo 12, imagem 1 %32
    • Remove the two 7.8mm Phillips #2 screws from the right back panel connected to the power port by turning the screwdriver counterclockwise.
  13. Wacom Cintiq 24HD Power Port Replacement: passo 13, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 13, imagem 2 %32
    • Lift the power port and attached daughterboard out of the device.
    • Remove the wires from the daughterboard.
    • Pull gently on the wires when removing from the daughterboard to prevent any tearing.
  14. Wacom Cintiq 24HD Power Port Replacement: passo 14, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 14, imagem 2 %32
    • Remove the two 8 mm Phillips #2 screws from the daughterboard by turning the screwdriver counterclockwise.
    • Detach the metal cover from the power port.
  15. Wacom Cintiq 24HD Power Port Replacement: passo 15, imagem 1 %32 Wacom Cintiq 24HD Power Port Replacement: passo 15, imagem 2 %32
    • Desolder the connections the power port connections using a soldering iron.
    • Remove the power port from the daughterboard by lifting it off.
    • iFixit has a guide to soldering which you can find here.
Conclusão
3 outras pessoas executaram este guia.
Sydney Hosokawa
Membro desde: 10/08/18
284 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S15-G3, White Fall 2018 Membro de Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
Membros da 4
Autoria de 18 guias
7 comentários
could you give the part, so i can buy it please
jmcl21 - Responder
My 24 HD blue power light comes on and off about once a second, you can hear the fan start and stop. Is a faulty power board the reason or is it the ps block ?
Thomas McGarrity - Responder
Hi,
Can you please tell me whrere I could buy the power port? I'm searching for several days and I couldn't find it.
tonet - Responder
Is there any where I can get this part the circuit board is damaged
Brian O'Kelly - Responder
any information regarding where to buy this component
Mario Romario -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 3,280
