Introdução
The fans on the Cintiq can break or become jammed. The fans on the Cintiq need to work properly in order to prevent overheating. This guide will show you how to open your device to remove the fans for cleaning or replacement.
O que você precisa
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
5Comentários do guia
Great instructions, but where to buy good replacement fans for this tablet?
so i was only able to find the exact fans only at one place. and it's overseas (china), so the delivery time is about 2 weeks minimum even with expedited shipping.
Fan ID-- SUNON GB1209PKB1-A 12V 2W 4wires Cooling Fan
website i found them : elecok.com
good luck. these instructions were close enough for the pro model of the 27" wacom cintiq.
don't attempt to open this without the Opening Tool or you risk cracking the screen. learned from experience.
Do any fans exist that can replace these very noisy fans and still do a competent job of keeping the equipment cool?
I want to disable the fans completely, will the monitor run if I just unplug the connector in step 13?
Lovely breakdown, thank you.
Looks like there's a big steel casing over everything. I wonder if you could run it without the plastic back cover?. Seems to me the metal inner case would make a nice heat sink but the plastic outer cover traps all the heat...
Cole Blotcky: Your pro 27 must have been within warranty at that point as they were only just out?. Wondered why you fixed it yourself, rather than sending it in? (just interested - thanks)
