Ir para o conteúdo principal
Wacker Pump PT3A 2012 Mechanical Seal Replacement
O que você precisa
  1. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Disconnect the spark plug wire: passo 1, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement, Disconnect the spark plug wire: passo 1, imagem 2 %32
    • Before you begin, make sure the device is switched off and the engine is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the pump housing cover: passo 2, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the pump housing cover: passo 2, imagem 2 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the pump housing cover: passo 2, imagem 3 %32
    • Use the included wrench to loosen the four black knobs securing the pump housing cover.
    • If the wrench is missing, slide a screwdriver shank through the knob and twist to loosen the knobs.
  3. Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 3, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 3, imagem 2 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 3, imagem 3 %32
    • Slide the pump housing cover out of the pump and remove it.
  4. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the recoil starter: passo 4, imagem 1 %32
    • Use a 10 mm socket and wrench to remove the three bolts securing the recoil starter.
  5. Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 5, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 5, imagem 2 %32
    • Remove the recoil starter from the engine.
  6. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Brace the driveline: passo 6, imagem 1 %32
    • Slide a large screwdriver through the slots in the starter cap and brace the screwdriver with a wooden block to prevent the driveline from turning clockwise.
  7. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the impeller: passo 7, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the impeller: passo 7, imagem 2 %32
    • Use a 19 mm socket, extension, and wrench to loosen the impeller from the driveline.
  8. Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 8, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement: passo 8, imagem 2 %32
    • Remove the impeller from the driveline.
  9. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the washers: passo 9, imagem 1 %32
    • Remove the two washers from the driveline.
    • Replace these washers if they look worn.
  10. Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the mechanical seal: passo 10, imagem 1 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the mechanical seal: passo 10, imagem 2 %32 Wacker Pump PT3A 2012 Mechanical Seal Replacement, Remove the mechanical seal: passo 10, imagem 3 %32
    • Use a flathead screwdriver to pry and loosen the mechanical seal from its recess.
    • Remove the mechanical seal.
Conclusão
Arthur Shi
Membro desde: 01/03/18
282.844 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.474 guias
Um comentário
what seal goes between pump and motor?
MARK - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 42
Duração total: 1,996
