Ir para o conteúdo principal
Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement
O que você precisa
  1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: passo 1, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: passo 1, imagem 2 %32
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: passo 2, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: passo 2, imagem 2 %32
    • For ease of access, swing the transport wheels underneath the plate compactor before you begin.
    • Use a 3/4" wrench to remove the two nuts securing the handle.
    • Use your palm to push against the shockmount to prevent it from slipping.
    • Remove the nuts and washers and retain them for reassembly.
  3. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: passo 3, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: passo 3, imagem 2 %32 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: passo 3, imagem 3 %32
    • Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
    • Slide the guide handle down enough to access the shockmounts.
  4. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: passo 4, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: passo 4, imagem 2 %32
    • Pull the shockmount out of the guide handle.
Conclusão
Arthur Shi
Membro desde: 01/03/18
316.738 Reputação
Autoria de 730 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.991 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 752
