Ir para o conteúdo principal
WRS315SDHW Refrigerator Thermistor Replacement
O que você precisa
  1. WRS315SDHW Refrigerator Thermistor Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: passo 2, imagem 1 %32 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: passo 2, imagem 2 %32 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: passo 3, imagem 1 %32 WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: passo 3, imagem 2 %32
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly (shown with the assembly removed).
  4. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: passo 4, imagem 1 %32 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: passo 4, imagem 2 %32 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: passo 4, imagem 3 %32
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: passo 5, imagem 1 %32 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: passo 5, imagem 2 %32 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: passo 5, imagem 3 %32
    • Disconnect the two harness connectors attached to the temperature control board assembly.
  6. WRS315SDHW Refrigerator Thermistor Replacement, Remove the assembly: passo 6, imagem 1 %32
    • Remove the temperature control board assembly.
  7. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: passo 7, imagem 1 %32 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: passo 7, imagem 2 %32 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: passo 7, imagem 3 %32
    • Pinch and pull the connector attached to the thermistor to disconnect it.
  8. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: passo 8, imagem 1 %32 WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: passo 8, imagem 2 %32
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 34
Autoria de 597 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Duração total: 178
