Ir para o conteúdo principal
WRS315SDHW Defrost Thermistor Replacement
O que você precisa
  1. WRS315SDHW Defrost Thermistor Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Thermistor Replacement, Open the doors: passo 2, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement, Open the doors: passo 2, imagem 2 %32 WRS315SDHW Defrost Thermistor Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: passo 3, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: passo 3, imagem 2 %32
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Thermistor Replacement: passo 4, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement: passo 4, imagem 2 %32
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: passo 5, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: passo 5, imagem 2 %32 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: passo 5, imagem 3 %32
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: passo 6, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: passo 6, imagem 2 %32 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: passo 6, imagem 3 %32
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: passo 7, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: passo 7, imagem 2 %32 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: passo 7, imagem 3 %32
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: passo 8, imagem 1 %32 WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: passo 8, imagem 2 %32
    • Disconnect the thermistor from the wiring harness.
  9. WRS315SDHW Defrost Thermistor Replacement, Remove the thermistor: passo 9, imagem 1 %32
    • Remove the thermistor.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 34
Autoria de 597 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 133
