Ir para o conteúdo principal
Vtech Kidizoom Smart Watch DX Circuit Board Replacement
O que você precisa
  1. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Master Switch: passo 1, imagem 1 %32
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 2, imagem 1 %32
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 3, imagem 1 %32
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 4, imagem 1 %32 Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 4, imagem 2 %32
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: passo 5, imagem 1 %32 Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: passo 5, imagem 2 %32
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 6, imagem 1 %32
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 7, imagem 1 %32
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 8, imagem 1 %32
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: passo 9, imagem 1 %32
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Conclusão
7 outras pessoas executaram este guia.
Jordan RiberSmith
Membro desde: 01/20/16
797 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 10-6, Remmell Spring 2016 Membro de USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Membros
Autoria de 12 guias
2Comentários do guia
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Jamar Mckay - Responder
Where can I buy replacement and how much should it cost?
Marisol Pelayo - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 42
Ao todo: 10,842
