Ir para o conteúdo principal
Vtech Kidizoom Smart Watch DX Buttons Replacement
O que você precisa
  1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: passo 1, imagem 1 %32
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 2, imagem 1 %32
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 3, imagem 1 %32
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 4, imagem 1 %32 Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 4, imagem 2 %32
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: passo 5, imagem 1 %32 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: passo 5, imagem 2 %32
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 6, imagem 1 %32
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 7, imagem 1 %32
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 8, imagem 1 %32
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 9, imagem 1 %32
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: passo 10, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the the tweezers to pull off the blue rubber cover behind the button.
    • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
  11. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 11, imagem 1 %32
    • Use tweezers to separate the backside tab from the front side of the button.
  12. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 12, imagem 1 %32
    • Push the other half of the button out of the casing.
    • Repeat steps 11 and 12 for all buttons.
Conclusão
Equipe
USF Tampa, Team 10-6, Remmell Spring 2016 Membro de USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Membros
Autoria de 12 guias
1Comentário do guia
Where can you buy the replacement cover?
Katrina Nullatamby - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 6,143
