Ir para o conteúdo principal
Vtech Kidizoom Smart Watch DX Battery Replacement
O que você precisa
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: passo 1, imagem 1 %32
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 2, imagem 1 %32
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 3, imagem 1 %32
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 4, imagem 1 %32 Vtech Kidizoom Smart Watch DX Battery Replacement: passo 4, imagem 2 %32
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: passo 5, imagem 1 %32 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: passo 5, imagem 2 %32
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 6, imagem 1 %32
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 7, imagem 1 %32
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 8, imagem 1 %32
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 9, imagem 1 %32
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: passo 10, imagem 1 %32 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: passo 10, imagem 2 %32
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 11, imagem 1 %32
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 12, imagem 1 %32
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: passo 13, imagem 1 %32
    • Pull the battery free, and wait for the solder to cool before handling further.
Conclusão
5 outras pessoas executaram este guia.
Navin Ramkishun
Membro desde: 01/20/16
271 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 10-6, Remmell Spring 2016 Membro de USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Membros
Autoria de 12 guias
1Comentário do guia
Where did you bought the battery?
funkysoulbrother - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 9,477
