Ir para o conteúdo principal
Vtech Kidibeats Drum Set Speaker Replacement
O que você precisa
  1. Vtech Kidibeats Drum Set Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Speaker Replacement: passo 2, imagem 1 %32
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Speaker Replacement: passo 3, imagem 1 %32
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Speaker Replacement: passo 4, imagem 1 %32
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Speaker Replacement: passo 5, imagem 1 %32
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Speaker Replacement: passo 6, imagem 1 %32 Vtech Kidibeats Drum Set Speaker Replacement: passo 6, imagem 2 %32
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Speaker Replacement, Speaker: passo 7, imagem 1 %32
    • Loosen and remove the two 10mm screws using a Phillips #00 screwdriver.
  8. Vtech Kidibeats Drum Set Speaker Replacement: passo 8, imagem 1 %32
    • Using your hand, gently remove speaker from its housing.
  9. Vtech Kidibeats Drum Set Speaker Replacement: passo 9, imagem 1 %32
    • Using a soldering station, carefully desolder the connection points on the speaker.
    • To review soldering safety and techniques, please visit Como soldar e dessoldar contatos.
Conclusão
Uma outra pessoa concluiu este guia.
Aaron Klementowski
Membro desde: 02/09/16
820 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-8, Cagle Spring 2016 Membro de USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 544
