Ir para o conteúdo principal
Vtech Innotab 3 Speaker Replacement
O que você precisa
  1. Vtech Innotab 3 Speaker Replacement, Rear Panel: passo 1, imagem 1 %32 Vtech Innotab 3 Speaker Replacement, Rear Panel: passo 1, imagem 2 %32 Vtech Innotab 3 Speaker Replacement, Rear Panel: passo 1, imagem 3 %32
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Speaker Replacement: passo 2, imagem 1 %32
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Speaker Replacement: passo 3, imagem 1 %32 Vtech Innotab 3 Speaker Replacement: passo 3, imagem 2 %32 Vtech Innotab 3 Speaker Replacement: passo 3, imagem 3 %32
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Speaker Replacement: passo 4, imagem 1 %32
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Speaker Replacement, Speaker: passo 5, imagem 1 %32 Vtech Innotab 3 Speaker Replacement, Speaker: passo 5, imagem 2 %32 Vtech Innotab 3 Speaker Replacement, Speaker: passo 5, imagem 3 %32
    • After you disassemble the device, put the back panel to the side and move your attention to the front piece.
    • Remove the four screws using a PH00 screwdriver.
  6. Vtech Innotab 3 Speaker Replacement: passo 6, imagem 1 %32 Vtech Innotab 3 Speaker Replacement: passo 6, imagem 2 %32
    • Using a nylon or metal spudger, lift the blue plastic piece upwards.
    • Keeping the plastic piece lifted, carefully pinch the edge of the speaker and remove it.
    • Be sure not to tug on the speaker too violently to prevent tearing a wiring from its solder.
  7. Vtech Innotab 3 Speaker Replacement: passo 7, imagem 1 %32 Vtech Innotab 3 Speaker Replacement: passo 7, imagem 2 %32 Vtech Innotab 3 Speaker Replacement: passo 7, imagem 3 %32
Conclusão
Zach Diviney
Membro desde: 03/11/15
419 Reputação
Autoria de 4 guias
Equipe
Colorado Springs, Team 5-4, Panko Spring 2015 Membro de Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 606
