Ir para o conteúdo principal
Vtech Innotab 3 Button Replacement
O que você precisa
    1. Vtech Innotab 3 Button Replacement, Rear Panel: passo 1, imagem 1 %32 Vtech Innotab 3 Button Replacement, Rear Panel: passo 1, imagem 2 %32 Vtech Innotab 3 Button Replacement, Rear Panel: passo 1, imagem 3 %32
      • Slide the battery compartment door lock down.
      • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
      • Carefully remove the batteries from the battery compartment.
      • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
      Pergunte ao FixBot
      Comentar
    2. Vtech Innotab 3 Button Replacement: passo 2, imagem 1 %32
      • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Vtech Innotab 3 Button Replacement: passo 3, imagem 1 %32 Vtech Innotab 3 Button Replacement: passo 3, imagem 2 %32 Vtech Innotab 3 Button Replacement: passo 3, imagem 3 %32
      • There are three hidden screws on the back of the device, two at the top and one near the bottom.
      • Using a nylon or metal spudger, remove the three caps that hide the screws.
      • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Vtech Innotab 3 Button Replacement: passo 4, imagem 1 %32
      • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
      Pergunte ao FixBot
      Comentar
    1. Vtech Innotab 3 Button Replacement, Button Repair: passo 5, imagem 1 %32 Vtech Innotab 3 Button Replacement, Button Repair: passo 5, imagem 2 %32 Vtech Innotab 3 Button Replacement, Button Repair: passo 5, imagem 3 %32
      • Remove the four 7.6 mm screws using a PH00 screwdriver.
      • Lift the circuit board up to give yourself room to remove the buttons.
      Pergunte ao FixBot
      Comentar
    2. Vtech Innotab 3 Button Replacement: passo 6, imagem 1 %32 Vtech Innotab 3 Button Replacement: passo 6, imagem 2 %32 Vtech Innotab 3 Button Replacement: passo 6, imagem 3 %32
      • Using a nylon or metal spudger, lift up the buttons to remove them from their holding. they should just pop out of place.
      • The buttons are joined together in pairs, be sure not to break them apart during removal.
      Pergunte ao FixBot
      Comentar
Conclusão
Zach Diviney
Membro desde: 03/11/15
419 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 980
