Introdução
Are the buttons no longer working on your tablet? This guide will walk you through replacing the buttons on the Vtech InnoTab 3S.
O que você precisa
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Using a Spudger, gently lift the brown squares located on the left and right sides of the tablet to gain access to the buttons.
Replace the malfunctioning buttons and lower the brown squares back into place to secure the buttons to the device.
Remove the motherboard to access the lower buttons. To remove the motherboard please see our Motherboard Guide
Now that the motherboard is removed, use a Spudger to gently lift the brown square at the bottom of the device.
Replace the malfunctioning buttons and lower the brown square back into place to secure the buttons to the device.
Uma outra pessoa concluiu este guia.
