Ir para o conteúdo principal
Vizio VTAB1008 Digitizer (Touchscreen) Replacement
O que você precisa
    1. Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Vizio VTAB1008 Back Cover Removal: passo 1, imagem 1 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Vizio VTAB1008 Back Cover Removal: passo 1, imagem 2 %32
      • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
      • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
      • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
      • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
      Pergunte ao FixBot
      Comentar
    2. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 2, imagem 1 %32
      • Look into the tablet for loose connectors.
      • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
      • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
      Pergunte ao FixBot
      Comentar
    1. Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: passo 3, imagem 1 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: passo 3, imagem 2 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: passo 3, imagem 3 %32
      • Remove the two screws present using the J1 Screw bit.
      • The screw has a head size of 4.3 mm and is 3 mm tall.
      Pergunte ao FixBot
      Comentar
    2. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 4, imagem 1 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 4, imagem 2 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 4, imagem 3 %32
      • Remove the two brackets accompanying screws by lifting them up and away from the screen.
      • Brackets are 8.5 mm by 6.55 mm.
      Pergunte ao FixBot
      Comentar
    3. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 5, imagem 1 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 5, imagem 2 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 5, imagem 3 %32
      • Separate the screen digitizer from the display screen, noting the placement of the quick disconnect ribbon cable.
      • Use a spudger if necessary to assist in the separation.
      Pergunte ao FixBot
      Comentar
    4. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 6, imagem 1 %32 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: passo 6, imagem 2 %32
      • The digitizer should now be able to be freely removed.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 27
Ao todo: 1,125
