Introdução
If your Vizio SmartCast Crave 360 (model SP50-DP) is making a muffled, fuzzy, or crackling sound, follow this guide to replace the bass component. A bass woofer producers the lower frequencies of music and sounds. A weak or broken bass woofer will create an unpleasant buzzing and scratching noise.
Before beginning, remove the Crave 360 from its charging base and turn off the device.
O que você precisa
Orient the speaker so that the bottom faces up.
Peel the rubber ring off of the bottom using the spudger.
4 outras pessoas executaram este guia.
