Ir para o conteúdo principal
Vizio SmartCast Crave 360 Bass Replacement
O que você precisa
  1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: passo 1, imagem 1 %32 Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Bass Replacement: passo 2, imagem 1 %32
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Bass Replacement: passo 3, imagem 1 %32 Vizio SmartCast Crave 360 Bass Replacement: passo 3, imagem 2 %32
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Bass Replacement, Bass: passo 4, imagem 1 %32 Vizio SmartCast Crave 360 Bass Replacement, Bass: passo 4, imagem 2 %32
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Bass Replacement: passo 5, imagem 1 %32 Vizio SmartCast Crave 360 Bass Replacement: passo 5, imagem 2 %32 Vizio SmartCast Crave 360 Bass Replacement: passo 5, imagem 3 %32
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 607
