Ir para o conteúdo principal
Visual Land Prestige Elite 9Q Speaker Replacement
O que você precisa
  1. Visual Land Prestige Elite 9Q Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connections begin to loosen.
  2. Visual Land Prestige Elite 9Q Speaker Replacement: passo 2, imagem 1 %32
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast.
  3. Visual Land Prestige Elite 9Q Speaker Replacement: passo 3, imagem 1 %32 Visual Land Prestige Elite 9Q Speaker Replacement: passo 3, imagem 2 %32
    • Once all connections have been loosened and using a soft surface, place the device onto its screen.
    • Open the casing and lay as shown in the picture keeping the speaker wires loose.
  4. Visual Land Prestige Elite 9Q Speaker Replacement: passo 4, imagem 1 %32 Visual Land Prestige Elite 9Q Speaker Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using ESD safe tweezers and a spudger, gently remove the glued speaker away from the casing.
    • The speaker is still connected to the motherboard with wire.
  5. Visual Land Prestige Elite 9Q Speaker Replacement: passo 5, imagem 1 %32
    • Next locate where the speaker's wires attach to the motherboard.
    • Make note of the red and black wires positions, for mixing them can cause permanent damage to your device.
  6. Visual Land Prestige Elite 9Q Speaker Replacement: passo 6, imagem 1 %32 Visual Land Prestige Elite 9Q Speaker Replacement: passo 6, imagem 2 %32
    • Before replacing the speaker, it's helpful to disconnect the LCD ribbon allowing sufficient space.
    • Remove the tape, and using hook tweezers, disconnect the LCD ZIF (zero insertion force) connection.
    • The ZIF connection takes manuvering, but the ribbon should be free and pushed out of the way.
  7. Visual Land Prestige Elite 9Q Speaker Replacement: passo 7, imagem 1 %32 Visual Land Prestige Elite 9Q Speaker Replacement: passo 7, imagem 2 %32
    • Before disconnecting the speaker, refer to Soldering Tips for proper soldering instructions.
    • Check the connection between the speaker and the motherboard. If it isn’t connected well, re-soldering the joint may fix the speaker.
    • Use a soldering iron the remove the speaker wires.
    • Ensure that each wire and solder connection do not touch. This will damage the device.
    • Note which nodes the wires are connected to, for replacement will occur in this order.
Conclusão
Joseph Justice
Membro desde: 07/19/16
175 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 302
