Ir para o conteúdo principal
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
O que você precisa
    1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: passo 1, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: passo 1, imagem 2 %32
      • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 2, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 2, imagem 2 %32
      • Wedge a plastic opening tool into the edges of the tablet to pry it open.
      Pergunte ao FixBot
      Comentar
    3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 3, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 3, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 3, imagem 3 %32
      • Wedge a curved metal spudger under the speaker in order to remove it.
      • The speaker is held in place by an adhesive and can be difficult to remove.
      Pergunte ao FixBot
      Comentar
    4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 4, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 4, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 4, imagem 3 %32
      • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
      Pergunte ao FixBot
      Comentar
    5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 5, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 5, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 5, imagem 3 %32
      • Use a plastic opening tool to lift the black tab.
      Pergunte ao FixBot
      Comentar
    6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 6, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 6, imagem 2 %32
      • Carefully lift and remove the ribbon cable from the black tab.
      Pergunte ao FixBot
      Comentar
    7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 7, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 7, imagem 2 %32
      • Use a plastic opening tool to remove the camera.
      Pergunte ao FixBot
      Comentar
    8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 8, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 8, imagem 2 %32
      • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
      Pergunte ao FixBot
      Comentar
    9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 9, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 9, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 9, imagem 3 %32
      • Lift the tape holding down the battery.
      Pergunte ao FixBot
      Comentar
    10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 10, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 10, imagem 2 %32
      Ferramenta utilizada neste passo:
      Plastic Cards
      $2.99
      Pergunte ao FixBot
      Comentar
    11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 11, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 11, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 11, imagem 3 %32
      Pergunte ao FixBot
      Comentar
    12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 12, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 12, imagem 2 %32
      Pergunte ao FixBot
      Comentar
    13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 13, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 13, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 13, imagem 3 %32
      Pergunte ao FixBot
      Comentar
    14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 14, imagem 1 %32
      • Safely remove the battery and motherboard from the tablet.
      Pergunte ao FixBot
      Comentar
    15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 15, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 15, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 15, imagem 3 %32
      • Lift the tape on the sides.
      Pergunte ao FixBot
      Comentar
    16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 16, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 16, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 16, imagem 3 %32
      • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
      Pergunte ao FixBot
      Comentar
    17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 17, imagem 1 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 17, imagem 2 %32 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 17, imagem 3 %32
      • Wedge a metal spudger underneath the LCD screen to remove it.
      Pergunte ao FixBot
      Comentar
    18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 18, imagem 1 %32
      • Replace the front screen to replace the digitizer.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UC Davis, Team 2-1, Oliver Fall 2016 Membro de UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 782
