Introdução
This guide shows how to remove the Visioneer OneTouch 7400 USB motherboard for repair or replacement.
WARNING: Circuitry will be exposed. Handle the motherboard carefully in order to avoid damage to the equipment and yourself. Keep the equipment away from heat sources and water.
O que você precisa
On the bottom half of the casing, remove the two screws in the motherboard.
