Introdução
If the capacitive buttons on the front of your humidifier are malfunctioning, then the motherboard controlling these buttons may need to be replaced.
O que você precisa
Orient the device so the nozzle is facing the ceiling.
Twist off the primary water holding cap.
Remove the three screws from the base of the device using a T20 Torx screwdriver.
Remove the base of the humidifier to access the components.
Quase terminado!
Conclusão
