O que você precisa
Passo 1 Prepare your phone
Cuidado: as etapas de 1 a 4 são provenientes de um guia marcado como em andamento.
Shut down your phone.
Set the phone down on a soft surface with space to store removed parts safely.
Unclip and remove the rear cover,
Remove any SIM/MicroSD cards.
Unscrew 12 black screws. A magnet is helpful for storing them. Try a fridge magnet face down.
Use a pick or your thumbnail around the display bezel to separate the frame from the phone.
Set aside the frame being careful not to lose the volume and power buttons.
Gently pry the battery plug up as shown.
Bend the cable up so the plug can't touch the board.
Unpick the white tabs from the top of the battery and pull gently and slowly as shown. Be careful not to snag the tapes. If both tapes come out cleanly the battery will be free. Hold the battery down with your other hand.
Unscrew the lower black cover (one screw top left) and lift it off.
Gently peel back any silver adhesive tabs attached to the board.
Carefully detach the coaxial cable and pry up the flat cable attached to the board.
Unscrew one silver screw (lower right) and gently pry the board out. It's held in by a black claw at the lower left.
Uma outra pessoa concluiu este guia.
