Ir para o conteúdo principal
Verizon Ellipsis Jetpack MHS800L Screen Replacement
O que você precisa
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, imagem 2 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, imagem 3 %32
      • Remove the SIM card, that is located on top of the Jetpack.
      Pergunte ao FixBot
      Comentar
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, imagem 2 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      Phillips #00 Screwdriver
      $5.49
      • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
      • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
      • You may need to peel back a piece of double sided tape covering the screw hole.
      Pergunte ao FixBot
      Comentar
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 3, imagem 1 %32
      • Remove three 1.25 mm screws.
      Pergunte ao FixBot
      Comentar
    4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 4, imagem 1 %32
      iFixit Opening Picks (Set of 6)
      $4.95
      Pergunte ao FixBot
      Comentar
    5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 5, imagem 1 %32
      • Once the cover is off, this is what your device will look like.
      Pergunte ao FixBot
      Comentar
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: passo 6, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: passo 6, imagem 2 %32
      • Once you have the case off of your device gently pull your battery away from the device.
      • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
      Pergunte ao FixBot
      Comentar
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 7, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 7, imagem 2 %32
      • With a pair of Tweezers remove the yellow tape covering the battery wires.
      Pergunte ao FixBot
      Comentar
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 8, imagem 1 %32
      • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
      • Do not squeeze the wires to hard you may damage them and cause a short.
      Pergunte ao FixBot
      Comentar
    4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 9, imagem 1 %32
      • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
      Pergunte ao FixBot
      Comentar
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, imagem 2 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, imagem 3 %32
      • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
      Pergunte ao FixBot
      Comentar
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 11, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 11, imagem 2 %32
      • Using the Tweezers gently coax the display data cable out of circuit board connector.
      • Do not squeeze the display data cable to hard you may damage it and cause a short.
      Pergunte ao FixBot
      Comentar
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 12, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 12, imagem 2 %32
      • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 3-3, Baechle Spring 2016 Membro de IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 2,515
