Ir para o conteúdo principal
Verizon Ellipsis 8 Disassembly
O que você precisa
    1. Verizon Ellipsis 8 Disassembly, Power Down and Remove Sim Card: passo 1, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Open SIM card flap and remove SIM card. Use a pair of tweezers to get the SIM card out.
      Pergunte ao FixBot
      Comentar
    2. Verizon Ellipsis 8 Disassembly, Remove Rear Cover: passo 2, imagem 1 %32
      • Use a guitar pick to open the cover of the tablet. For most effective results, start at the corner of the tablet and continue.
      • **BE SURE NOT TO DAMAGE THE SIM CARD OR SD CARD SLOTS**
      Pergunte ao FixBot
      Comentar
    3. Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: passo 3, imagem 1 %32 Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: passo 3, imagem 2 %32
      • Continue opening the cover now using a metal spudger and wiggle it to pry the cover open.
      • You can look at the picture of the rear cover to see where the snaps are located.
      Pergunte ao FixBot
      Comentar
    4. Verizon Ellipsis 8 Disassembly, Remove Battery: passo 4, imagem 1 %32
      • Remove the screws attached to the circuit board on the battery using a Phillips 00 screw head and remove the battery.
      • There was no adhesive on the back of the battery, just along the sides.
      Pergunte ao FixBot
      Comentar
    5. Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: passo 5, imagem 1 %32 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: passo 5, imagem 2 %32 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: passo 5, imagem 3 %32
      • Be careful when removing the ribbon cables as there is adhesive on the back of them. To remove the cables flip up the rear part of the connector to slide the cable out - *gently*.
      • The USB Charging Connector and the Antenna Board both have adhesive on the back. Remove the screws and carefully lift up on the boards to remove them.
      • **Be careful with the antenna cable!**
      Pergunte ao FixBot
      Comentar
    6. Verizon Ellipsis 8 Disassembly, Remove Mainboard & Speaker: passo 6, imagem 1 %32
      • Remove the 5 screws holding the Mainboard and Speakers in to place. *One of the screws is under the ribbon cable*
      • There was no adhesive holding this board in and the whole assembly lifted out as one piece.
      Pergunte ao FixBot
      Comentar
Conclusão
31 outras pessoas executaram este guia.
SMcC21985
Membro desde: 11/10/15
1.271 Reputação
Autoria de 2 guias
4Comentários do guia
what size screws are thoze i need to get some i lost some
stacy - Responder Compartilhar
My tablet is on, when I press to Open , it doesn't do anything
Gladys Lockhart - Responder Compartilhar
My tablet is on working, when I press to get is frozen, it doesn't let me in
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 58
Ao todo: 21,383
