Ir para o conteúdo principal
Verizon Ellipsis 8 Button Replacement
O que você precisa
    1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: passo 1, imagem 1 %32
      • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
      Pergunte ao FixBot
      Comentar
    2. Verizon Ellipsis 8  Button Replacement: passo 2, imagem 1 %32
      • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
      Pergunte ao FixBot
      Comentar
    3. Verizon Ellipsis 8  Button Replacement: passo 3, imagem 1 %32
      • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
      Pergunte ao FixBot
      Comentar
Conclusão
Jack
Membro desde: 02/06/19
610 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S18-G6, Lore Winter 2019 Membro de UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 Membros
Autoria de 3 guias
1Comentário do guia
where can i purchase replacement buttons for this device? anyone know? Thanks!!!
Broadcast Depth - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 798
