Introdução
This guide will show how to replace a defective power button on the Verizon Ellipsis 7.
O que você precisa
Power down device by holding down the power button until the screen goes black.
Remove the SIM card from the device to prevent damage.
To remove the SIM card, open the SIM card cover on the side of the device.
Push SIM card in, then remove after it pops out with an audible click.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
Be extremely careful when disconnecting the ribbon cable. It is very delicate.
2Comentários do guia
I dropped mine and the button is broke. It looks like I should be able to just pop it back, but it's not reaching the button in the tablet. Do I really have to order this just for it to turn on? I mean, I use a paper clip, but I use this for Uber and it's not safe when I'm driving, lol.
I have looked everywhere for replacement buttons. Any help you can give in finding the parts is appreciated.
