Ir para o conteúdo principal
Verizon Ellipsis 7 Charging Port Replacement
O que você precisa
    1. Verizon Ellipsis 7 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Verizon Ellipsis 7 Charging Port Replacement, Charging Port: passo 1, imagem 2 %32 Verizon Ellipsis 7 Charging Port Replacement, Charging Port: passo 1, imagem 3 %32
      • Hold down the power button until the screen goes black to turn off the device.
      • Remove the SIM card from the device to prevent damage.
      • To remove the SIM card, open the SIM card cover on the side of the device.
      • Push SIM card in and pull it out after hearing a click.
      Pergunte ao FixBot
      Comentar
    2. Verizon Ellipsis 7 Charging Port Replacement: passo 2, imagem 1 %32 Verizon Ellipsis 7 Charging Port Replacement: passo 2, imagem 2 %32
      • Take off the back panel.
      • Pry open the back cover carefully with a plastic opening tool.
      • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
      • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
      Pergunte ao FixBot
      Comentar
    3. Verizon Ellipsis 7 Charging Port Replacement: passo 3, imagem 1 %32 Verizon Ellipsis 7 Charging Port Replacement: passo 3, imagem 2 %32 Verizon Ellipsis 7 Charging Port Replacement: passo 3, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Remove the charging (micro-USB) port.
      • Unscrew the indicated screws using the Phillips #00 screwdriver.
      • The screws shown in the picture are the more common 4.76 mm.
      • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
      • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
      • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
      Pergunte ao FixBot
      Comentar
    4. Verizon Ellipsis 7 Charging Port Replacement: passo 4, imagem 1 %32 Verizon Ellipsis 7 Charging Port Replacement: passo 4, imagem 2 %32
      • Remove the charging port board from the phone using tweezers.
      • Place the replacement charging port into the phone.
      • Be cautious when replacing the ribbon cable onto the new charging port board.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
4Comentários do guia
Guide was helpful in getting the back cover off.
I used a couple of guitar picks to pry the back cover off very carefully.
The Ellipsis 7 battery is glued into place.
I slid a credit card underneath the battery to break the glue adhesion from
the far end of the battery and worked my way towards the battery connector.
Just before removing the battery completely, I disconnected the battery connector
by prying it away from it's receptacle using the 2 guitar picks.
I positioned the credit card over the still sticky glue while positioning the battery.
Reattached the new battery connector, making sure no wires were caught under the new battery.
I then removed the credit card over the sticky glue and pressed the onto the metal battery mount plate.
Snapped the back cover on, starting at the end furthest away from the camera aperture, then snapped the back
cover up each side simultaneously up the sides. I tested all tablet functions immediately, as the battery came charged to 75%.
Works so far! Walt Taylor
Walter Taylor - Responder Compartilhar
How do I get a Verizon Eclipse 7 charging port how can I order one how can I buy one please let me know
Jeffery - Responder Compartilhar
How can the charging port if the part is not available?
Joe M
Joseph Malcor - Responder Compartilhar
Perhaps if the author would provide the part number and/or compatible replacement parts it would be even more helpful!
Larry R - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 47
Ao todo: 14,501
