Ir para o conteúdo principal
Verizon Ellipsis 10 Camera Replacement
O que você precisa
  1. Verizon Ellipsis 10 Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Open the SD/SIM card cover to start prying off the back cover.
    Pergunte ao FixBot
    Comentar
  2. Verizon Ellipsis 10 Camera Replacement: passo 2, imagem 1 %32
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
    Pergunte ao FixBot
    Comentar
  3. Verizon Ellipsis 10 Camera Replacement: passo 3, imagem 1 %32
    • Follow along the edge of the device to undo all of the retaining clips.
    Pergunte ao FixBot
    Comentar
  4. Verizon Ellipsis 10 Camera Replacement: passo 4, imagem 1 %32
    • Once all the clips are undone, the back panel should come off with little effort.
    Pergunte ao FixBot
    Comentar
  5. Verizon Ellipsis 10 Camera Replacement, Battery: passo 5, imagem 1 %32
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
    Pergunte ao FixBot
    Comentar
  6. Verizon Ellipsis 10 Camera Replacement: passo 6, imagem 1 %32
    • Remove the top piece of tape using an iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  7. Verizon Ellipsis 10 Camera Replacement: passo 7, imagem 1 %32
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
    Pergunte ao FixBot
    Comentar
  8. Verizon Ellipsis 10 Camera Replacement: passo 8, imagem 1 %32
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
    Pergunte ao FixBot
    Comentar
  9. Verizon Ellipsis 10 Camera Replacement: passo 9, imagem 1 %32
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
    Pergunte ao FixBot
    Comentar
  10. Verizon Ellipsis 10 Camera Replacement, Camera: passo 10, imagem 1 %32
    • Remove 4 M1.5 screws holding in the labeled LTE module.
    Pergunte ao FixBot
    Comentar
  11. Verizon Ellipsis 10 Camera Replacement: passo 11, imagem 1 %32
    • Use a nylon spudger to pry up the module.
    • It's held in with some clips so there will be a little bit of resistance.
    Pergunte ao FixBot
    Comentar
  12. Verizon Ellipsis 10 Camera Replacement: passo 12, imagem 1 %32 Verizon Ellipsis 10 Camera Replacement: passo 12, imagem 2 %32
    • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
    • The module should come up with a little resistance.
    Pergunte ao FixBot
    Comentar
  13. Verizon Ellipsis 10 Camera Replacement: passo 13, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to lift up the front camera off its locating post.
    Pergunte ao FixBot
    Comentar
  14. Verizon Ellipsis 10 Camera Replacement: passo 14, imagem 1 %32 Verizon Ellipsis 10 Camera Replacement: passo 14, imagem 2 %32
    • Remove the non-conductive tape covering the camera ribbon cable.
    • You may need to remove the white antenna cable to remove the tape.
    Pergunte ao FixBot
    Comentar
  15. Verizon Ellipsis 10 Camera Replacement: passo 15, imagem 1 %32
    • Carefully unplug the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  16. Verizon Ellipsis 10 Camera Replacement: passo 16, imagem 1 %32 Verizon Ellipsis 10 Camera Replacement: passo 16, imagem 2 %32
    • Peel up the ribbon cable carefully as it is glued to the device.
    • After having peeled up the cable, the cameras should be free to come out of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 322
