Ir para o conteúdo principal
Verizon Ellipsis 10 Battery Replacement
O que você precisa
  1. Verizon Ellipsis 10 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Open the SD/SIM card cover to start prying off the back cover.
    Pergunte ao FixBot
    Comentar
  2. Verizon Ellipsis 10 Battery Replacement: passo 2, imagem 1 %32
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
    Pergunte ao FixBot
    Comentar
  3. Verizon Ellipsis 10 Battery Replacement: passo 3, imagem 1 %32
    • Follow along the edge of the device to undo all of the retaining clips.
    Pergunte ao FixBot
    Comentar
  4. Verizon Ellipsis 10 Battery Replacement: passo 4, imagem 1 %32
    • Once all the clips are undone, the back panel should come off with little effort.
    Pergunte ao FixBot
    Comentar
  5. Verizon Ellipsis 10 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
    Pergunte ao FixBot
    Comentar
  6. Verizon Ellipsis 10 Battery Replacement: passo 6, imagem 1 %32
    • Remove the top piece of tape using an iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  7. Verizon Ellipsis 10 Battery Replacement: passo 7, imagem 1 %32
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
    Pergunte ao FixBot
    Comentar
  8. Verizon Ellipsis 10 Battery Replacement: passo 8, imagem 1 %32
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
    Pergunte ao FixBot
    Comentar
  9. Verizon Ellipsis 10 Battery Replacement: passo 9, imagem 1 %32
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
3 outras pessoas executaram este guia.
1Comentário do guia
Has anyone found a source for these batteries?
brianmjones - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 2,236
