Ir para o conteúdo principal
Vent Panel Disassembly
O que você precisa
  1. Vent Panel Disassembly, Remove Service Panel Screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
    Pergunte ao FixBot
    Comentar
  2. Vent Panel Disassembly, Dislodge Service Panel: passo 2, imagem 1 %32 Vent Panel Disassembly, Dislodge Service Panel: passo 2, imagem 2 %32 Vent Panel Disassembly, Dislodge Service Panel: passo 2, imagem 3 %32
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
    Pergunte ao FixBot
    Comentar
  3. Vent Panel Disassembly, Remove screw covers: passo 3, imagem 1 %32
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
    Pergunte ao FixBot
    Comentar
  4. Vent Panel Disassembly, Unfasten vent panel: passo 4, imagem 1 %32 Vent Panel Disassembly, Unfasten vent panel: passo 4, imagem 2 %32
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
    Pergunte ao FixBot
    Comentar
  5. Vent Panel Disassembly, Remove vent panel: passo 5, imagem 1 %32 Vent Panel Disassembly, Remove vent panel: passo 5, imagem 2 %32
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
    Pergunte ao FixBot
    Comentar
Conclusão
iodyne
Membro desde: 01/01/22
462 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 399
