Introdução
Follow this guide to replace the motherboard in a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
O que você precisa
Use your hand to pull the front cover straight off of the front of the headset.
Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
Four 6.3 mm screws with fine threads
Four 6.0 mm screws with coarse threads
Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
Disconnect the FPC ribbon cable from the motherboard.
Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Uma outra pessoa concluiu este guia.
5Comentários do guia
Where can I buy the motherboard? It doesn't look like ifixit has them.
I have this same question.
Same question ,where do i get a replacement main board
